Surf Fins for the Blaster could possibly be one of the most noticeable add on's ever to be built. These Surf Fins have been developed through a R&D programme by the 701 Test Pilots and are now available for every Blaster Freerider. The 701 Surf Fins are way more than just a fin that angles out from the gunnel rail. Once you fit the Surf Fin, you have actually lowered your bond line by 2 inches. With the Blaster having a high sides, the rear would have to sink in from a jump so much so it was hard to recover. Now with the Surf Fins attached, the bond line now lower, adds up to a massive difference. With the Fins added , this makes for a lot larger surface area to catch the water and slow the sinking of the rear. The added feature of the Fins being able to flex on landing, instantly increases the resistance as they flare out. Whether you jump, flip or roll, these Surf fins are the ultimate add on for instant recovery. http://www.701industries.com/
