superjet?
Shonuff
I've got the glow
Memphis
Here's the listing:
Engine rebuild consisted of:
* Bore cylinders
* New Yamaha pistons and rings
* New Yamaha crankshaft and crank seals
* New Yamaha wrist pin bearings, pins and clips
Engine Modifications are:
* 6M6 Cylinder fitted with 701 sleeves from L.A.Sleeve
* Pro-Tec porting
* Pro-Tec Cylinder cut to .0650" squish clearance and 185 psi compression
* 9200 rpm rev limiter
* Boysen reeds
* Factory Pipe 'B' pipe
* Factory Pipe aluminum water box
* Pro-Tec Taper Bored Dual 44mm Carbs. with matched flame arrestor adapters mounted on a Pro-Tec manifold
* K&N flame arrestors with Riva wet-suits
The ski features:
* Aluminum handle pole, steering and throttle cables were replaced with handle pole
* UMI steering set up with adjustable turn plate
* UMI handle bars
* Rule automatic bilge pump with handle bar mounted manual override switch, also retains stock bilge system
* Hydro-Turf mats
* Pro-Tec ride plate
* Westcoast intake Grate
* Solas Prop
If everything runs as it should, it should be a great ski for around $1800-$2000.
It's a Pro-Tec bored up and ported 650-to-701 (so really a 701 displacement)
Certainly more powerful than stock 701 - nice engine.
njfl
X-H2
I'd go with the modded one, especially if it has the b-pipe. That's a $500 investment that you'll soon want anyway. It looks like the pipe rubbed through the upper body. That's no big deal. If it is still rubbing, put a piece of turf between it and thehull. If I read the description correctly you are looking at the ski that is the 92 that he only mentions in th ebottom of the listing. Make sure that he starts and revs it for you as he mentioned that he does not want to put a cheap battery in it. Bring a good battery with you or ask him to borrow it from the other ski.
The only limitation I see with that ski is the 6m6 cases. You could eventually swap to 62T cases, and run a 61x cylinder if you wanted, and it wouldn't cost too much. The B pipe is definitely a plus, although it has the 650 chamber; but chambers are easy to come by. Good luck! -Kurt
so is that necessarily bad? I dont know much about these, so any info would help. He says its a 650 ported to a 701, which Matt E says is more powerful than a stock 701? The only reason i would have to upgrade then is to a 760.
aof13
Sfl free since 3/28
The ports are definitely smaller on the 701 bored out from a 650.
It's bad in stock form. A 650 bored up to 701 will not perform as well as a real 701. The ports on the 701 are bigger (though they are lower on the 650! (Good))
Additionally, the ports on the 650 are sized for the 650 bore, so when you bore up they need to be enlarged.
That said, it's fairly simple to enlarge the exhaust ports to at least stock 701 size.
