Super Jet superjet won't start
So my friend call me to help her with her superjet. when I push start on the switch, nothing happen. so I open the electric box, tried the jumping trick with a screw driver at the solonoid and the engine was turning. I did realize that the fuse is not there anymore. Probably the person before remove it and jump the 2 wire. I have tried to see if the problem is from the start stop switch, I unplugged the White/Black Wires on the start switch and tried to jump the Red/Brown start wire and nothing. what that mean? and what else I have to try?
I think that I found my prpblem, I disconnect the black and white wire from the start/stop switch and push start and nothing happen. then I disconnect the brown and red wire from the start/stop switch and jump the 2 brown and red that goes to the ebox. it crank right up. so that mean that the start and stop is bad?
swapmeet
Brotastic
Arlington TX
If Ricksters idea doesn't work....
My buddy and I have been experiencing similar issues recently.
Power runs through the lanyard switch, take it out of the case, unscrew the four screws and carefully pull it apart. Theres many small parts (springs and H shaped contacts) inside that might fall out. Make sure everything is clean. I think you can put some dielectric grease in there but not sure. My buddy was able to clean the contacts and get it working. Mine was really bad, chunks missing out of the copper contacts etc. I had to replace it.
GL
Rickster
Matakana Menace
GL
That's what I said above... lol
