- Enfield, CT
Ive got a 95 superjet that wont start nor do i hear anything at all. It worked perfect last week when i used it. The following things are what i think may be the problem:
Lanyard? Dont know how to check/test it. It simply doesnt start
Bad start/stop switch? Dont know how to test
Battery? Its showing 12.18V, seems a little low but pretty sure its got less then 5hrs on it
Bad wires? The inside is nearly mint with no corrosion, rust or sludge on any of the connestions
Something in the electronic box? Ive got an volt meter so i can test whatever (starer relay?)
Starter? I bench tested it and it turned but sparked like crazy, not sure if i did it right but it spun
Spark plugs/wires? No corrosion and plugs look good
Forgot to mention i checked plugs and they look good. Pistons look good as well, motor turns freely by hand so its not seized.
Not sure what it coukd be. I didnt check everything above, but if i can get some help testing parts and how, id appreciate it. Thank you
