- USA
I am trying to install softer throttle shaft springs on my 2019 SuperJet Mikuni carbs. Easy enough to access the one on the end, but how do I get to the one in the middle? Per the pics, it is underneath an air intake manifold of sorts. Presume I need to remove it? If so, any suggestions on the easiest way would be much appreciated. Or if there is a way to change it without I would love to know.
If difficult, I may opt to change only the outer. It is tempting to remove the outer spring and go interior spring only for 1/2 the pull, but my guess is that becomes a single failure point risk.
Thank you for any help!
