superjet starting problem
ok so the other day my start stop button did nothing so i took the ebox apaert to find a good amount of corrosion in it i cleaned the hole box up filed all the ground and put it back together and it was fine and would work ever time i hit the button, i went to the hudson to ride and i had the same problem all over againg but this time i cleaned it up and it would start againg. i have since changed out the start stop and the relay with no luck. if i jump the terminals the starter gets power and turns the motor over. iam kinda stumped and the only thing left is the small section of the wire harnes going into the ebox rite?????
Proformance1
Liquid Insanity
Vendor Account
New York Crew
check for corrosion of the red or brown wire, i cant remember which one, in the pulg end going from start stop to ebox. clean it up and dielectric grease the heck out of it.
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
Double check both connectors from the ss switch, they like to corrode and loosen up.
Also, try this test - unplug the connector coming out of the e-box that goes to the ss switch (the one with black and white wires). Try and start your ski - if it starts, your lanyard switch is bad. If it starts, just remember to plug that connector back in to kill the motor.
