Superjet start problem help!
I own a 2008 superjet it fan fine last weeken and now when i started it, it didnt crank so i charges the battery and mounted the connections and it starts as soon as i put both connections on the battery not with the starter botton, any ides?
Tuscaloosa, AL
not quite understanding what your saying (Translation issues?), Sounds like your saying that you can jump the solenoid and it will start up, but not with the start stop switches. Sounds like your start switch is messed up. Unplug it. the plug coming from the ebox. take some needle nose pliers and jump the brown and red wire together, see if it spins over. if it does. take apart the start stop switch and clean the contacts and the connection disc.
Yes im not the best at english, but when i hook up positive and ground wires to the battery it cranks the engine directly without me pushing the start botton, and when i disconnect the start stop switch and hook up positive and ground to battery it starts directly
Tuscaloosa, AL
your solenoid is stuck in closed position. (Open when not hitting the start button). This would cause the starter to engage no matter what when you connect the battery.
