- Sliedrecht
Do these spark plugs look like my engine in running lean? Spark plugs are 2 weeks old and used for 3 times i think. And if so, whats te solution? I checked the settings of the carb and they are correct
Should i just turn the main jet a little further out.
Stock 2016 superjet. I have the feeling that it lean seized on me 2 times past weeks. Bougt the sj couple months ago, but when i run it long and hard on the track it suddendly died. Like engine stopped instandly. First time it was hard to start, second time it fired right up after.
Compression is low (on cold engine, didnt do anything to prepare the compression test) but equal on both cylinders (100psi). I mix oil at 40:1, or more
