Superjet Disabling vis spout
Good day skiers! Have a question about blocking off visibility spout. I pulled hose off and capped outlet with plug. Yesterday, I took off ride plate to work on corrosion, and noticed behind reduction nozzle, there is a hose from hull going in... should I disable and cap this too? Just thinking about when I winterize, I don't want to leave water anywhere that may cause a problem the following spring.
