Superjet completely stopped running correctly - Clueless
So I just finished tuning my carbs and dialed in my superjet. It was running great and I was trying to learn turn subs. After a few it started to run a little strange like there was too much water. I had the bildge on and when i got to shore, it drained for a very long time. I tried to go back out, and it just was dying on me. It eventually wouldn't start.
I pulled the plugs and replaced them. I was getting current running through but I couldn't visually see any electricity flowing when trying to start when pulled. After changing the plugs it was starting again but it wasn't firing right. No matter how much throttle I gave it, it would go the same speed. There was no oumph so to speak.
I thought there might have been water in the gas so I drained and replaced. It fired up and ran OK for 20 seconds and then back to bogging again as before. I thought maybe it needed to circulate all the new gas so I tried to ride it for a minute. Then it died and upon starting up, my legs started getting shocked in the water. Thought maybe i was imagining things but I tried it a few times and every time I could feel a very mild current of electricity in the water.
At this point, I have no idea what to do or what the issue is. Let me know your thoughts!
Quinc
Buy a Superjet
California
check your battery, make sure your ebox is not wet inside, buy a spark tester and make sure you have spark. Is your engine full of water?
You need to give your ski some time to drain all the water out of the hull between subs.
