Super Jet Superjet almost complete. Any final suggestions?
This winter I had to replace a worn driveshaft on my SJ. In the process I decided to replace/add a bunch of other parts as well. I am looking to get my ski in the water this weekend and was wondering if I am overlooking anything or in need of checking/tuning things.
The ski got the following:
B Pipe w/ lim chamber
Mikuni got new jets per B pipe recommendations
lightened flywheel by #zero
milled head by #zero
footholds
defoamed/refoamed
protec intake grate
JM hoot strap kit
I understand my carb will need adjusting and tuning based on different things but was wondering if I need to check/change the pop off pressure or if you guys can think of anything else I might be overlooking before I get out on the lake (49 degree water temp) and think man I should have done this in the garage instead of water. Thanks for the help!
These are the jets and specs I will be running.
Main Jet : 145
Pilot Jet : 120
High speed screw : 12 turns out from closed
Low speed screw : 2 2 turns out from closed
Needle & Seat : Stock
Spring : 95 gram
