Super jet hull motor mounts
AJs
Mn
Hey guys
I had a motor mount bolt sear off and could not remove it without damaging the bras insert and threads. Anyone know how to repair that? I assume new brass sleeve and epoxy it in
any help us greatly appreciated. Thanks
I have drilled the insert and put a heli-coil in before. It was on an aftermarket ski with aluminum inserts, but there should be enough thickness on the brass inserts.
