masterblaster
X-H2
what oil ratio do most of you that run power motors run. I do fine with 50/1 in my ported 701 but have been runnin 40/1 in the stroker.I hear that 30/1 can make more power but I dont see how that is possible more lube or not?
as far as octane goes I keep hearing guys say their motor makes more power on race fuel than pump but does ok on pump,I dont get this either on a motor with fixed timing. I can see it on a obd2 system motor with knock sensoring pulling timing. but how does a motor thats setup with timing and comp to at least accept pump fuel that is hotter burning run better with no changes other than race fuel? I can see maybe oxygenated race fuel,but av gas or 100 or even 110 leaded?
I always thought the octane was a safty factor that allowed for more timing,comp,porting to make more power,but i dont get the reverse factor here?
