Super Jet Stripping paint from fiberglass
Fstrkls1
Fast and Reckless
Manteca ca
Im currently modding my my pole and need to strip a bunch of paint to do Fiberglass work. My question is what to use thAt won't mess up the fiberglass or factory eppoxy? I was thinking about trying jasco but am not sure. Has any one delt with this before? Any info or advice would be great thanks in advance
D-ville
I've used aircraft stripper on mine without any ill effects, I just make sure to clean it off quickly after the paint has been removed. Been riding one hull for 4 years since stripping it and haven't seen any problems
grezzmky
Suckin paint fumes
Saint Louis MO
+1 home hardware stores too
could not find any at lowes today. the guy showed me some strippers and when i didnt grab one he said "what? weve got latex, oil based.... what do you need?" I said " I need the REAL stuff, air craft stripper" H said "AIRCRAFT STRIPPER, this is LOWES" haha
grezzmky
Suckin paint fumes
Saint Louis MO
And hey the :):):):) BURNS and it is actually nutrilized with laquer thinner. so belive it or not, when you get it on your fore arm and it starts to burn like youve never felt before neutralize it with thinner.
..... still dont know why your need to chemicly strip a pole though...
Small wire wheel on die grinder. Works great for stripping the paint, and roughing it up for glasswork at the same time. It wont cut in if you dont go hog wild for 5 minutes in 1 spot.
I went to autozone and picked up some aircraft remover, and since I didnt have any aircraft sitting around I used it on my hood. Works pretty good if you wait the time it says to.
