Strange thing - 2007 SJ - emissions control??
Polish jet pilot
4aces4aces4aces4aces4aces
Warsaw, Poland
A customer brought in a 2007 SJ with drowned motor. I started looking at the parts and noticed that:
- these carbs (2x38mm mikuni) have no Low or High adjusters!!
- the oem exhuast seems to have some sort of insert that looks a bit like it is supposed to affect emissions
Anybody any comments on this?
SUPERTUNE
Race Gas Rules
Clearwater Fl.
All the U.S. models are like that since '07.
The adjuster screws are under a pressed in cap to make them what they call 'Tamper Proof' carbs.
Not any fun to remove, but can be done by drilling them out.
R
ridethelip
Guest
use left hand turning drill bits if you can get some. Common drill bits turn in a clockwise direction and when drilling through the anti tampering caps with that style it is possible to go through cap hit mixture screw and screw mixture into carb and damage carb. if thats all you got you can make a drill depth limiter out of copper tube. Another way is to use a die grinder from the side
