stock superjet need mod advice!
coolmann7
Jeff @ WDK is a CROOK!
North Iowa
so i have a 07 sj thats basically brand new and stock.... i need help what do you guys suggest for mods... intake and prop? should i do a pipe right away too? I can spend around 1000.
thanks
coolmann7
North Iowa
last time i looked for a b pipe they were out of stock... are they available now and where do i get it. what make of prop and pitch?
Look around for B-Pipes.
Try Jetworks, Blowsion, Wamiltons, etc. I bet somebody has one.
SJBrit
Extraordinary Alien
Bradenton, FL
I agree on prop and pipe, but I would get rid of that stock intake too and swap for a Worx 201. That makes a big improvement to a stock.
#!. B-PIPE! just did this and it was crazy the amount of power that just one mod makes to a stock motor! Order from FACTORY PIPE website.... Just call them direct and order from them over the phone, gonna save you at least $80 going direct.
And get some footholds ASAP, to keep you glued to that ski and not breaking ankles....
coolmann7
North Iowa
Manfish what footholds did u go with? and i just saw your post on you ADA head where are you buying your parts like that..... whos the cheapest out there. Most likely i'll be ordering my b pipe today! :)
munki63
Epoxy is my duct tape
Canada
They should be instock today I just talked to them yesterday, I'm not sure if your stock carbs were like mine but I didn't have adjustment screws on mine so you might want to look in to that as well, but footholds and pipe for my 2cents
Shifty
- SuperJet Thursday -
If you still have the stock aluminium impeller (green in color) you will need to upgrade that ASAP as well. Expect to spend anywere from $70-250 on an impeller. A pipe will be your best bang, though a fairly expensive one. Footholds will really allow you to control your ski with more authority. If your comfortable you could also bump your timing a tad or go with an MSD Enhancer after your pipe install ($200ish?).
If your ordering your pipe, make sure to get two sets of jets. I think Factory Pipe only sends one set (check with them for sizes). Also check your carburetors for tamper plugs I know mine had them (2008) I think the '07's used them too. If it does you will not be able to adjust your carbs for you new pipe. While you wait for your pipe to arrive you might go ahead and get to removing them. Do a search for "tamper caps" to get all the details/ pictures.
I have the new XFT holds! By far the best out there to date.... Good luck getting ahold of sergio or even being able to get some because he has been m.i.a for some time..... For my parts like the pipe and the head i always go straight to the manufacturer. Going direct is by far the cheapest, I got my pipe from factory, i got my head from ada. I am running 135 mains on a set of protec 38's. Just order the adjustment screws from blowsion and your stock carbs should be just fine.....I get all my other stuff from blowsion. Good guys, good stuff.
Ill post some pictures of my holds in a few days when I get the front hold in......
:smokin::smokin::smokin:
