onesojourner
I use a thumb throttle.
- springfield, mo
can some one tell me if this is right?
Looks like someone rebuilt two at a time instead of one at a time.
The pulse inlet and subsequent pump body goes on the first carb.
Incorrect.
The pump is on the right (back) carb.
However, it appears that it was installed 180 degrees off.
The pulse nipple needs to point towards the back of the ski, not towards the front as it is now.
Take the carbs apart, make sure that you installed everything correctly, and then reassemble correctly.
