Super Jet Stock 701 Exhaust Plumbing question??
Utah
I'm hooking up a stock exhaust to a ski I have, my question is on the plumbing. I have a tube that has a tee with two small lengths of pipe on each side and long length on the other. I'm assuming the tee goes to the head and to the exhaust manifold and the long length would go to the pisser? Where does the tube coming from the firewall go?
TheCoz43
Jet Surfer
Pismo Beach, CA
Hope this helps, here is diagram one for stock head single cooling line, and also for dual.
attachment.php
attachment.php
Utah
attachment.php
attachment.php
Thanks for the help... I figured it out, there are actually two ports on the stock exhaust manifold. Line from the firewall or the pump to the bottom port on the exhaust manifold. T-line goes to head and the exhaust manifold out to the pisser... Thanks again.......
I just took mine off to put a b pipe on and it ran like this, i don't have a diagram but can explain it. From the firewall to the exhaust manifold then the head to the head pipe and the t goes in between those two. Then the pisser comes off the 90 degree part of the tee.
