Super Jet Steering keeps self tightening
I have a universal cold fusion turn plate using stock bushings and nuts and when I ride for a few minutes the bars get super hard to turn to the point I have to go back to shore. It's as if the top nut is rubbing against the round washer plate that sits on top of it causing it to tighten, similar to a ratchet. Only solution I found so far is to have the bars so loose that they are not in contact with the bottom of the turn plate, although I do not like doing this. Would getting the cold fusion turn plate locking clamp nut fix this ? Or is it my stock bushings ?
is your lock nut tight? i've got a cf plate with stock bushings and have never had an issue.. but i could see if you've only got the one nut on it that it could tighten up...
