Stator replacement
It's in a 650 SJ. I've never messed with the stator before. How difficult would it be to replace a single coil on the stator assembly? What all would be involved with it? is it just screwed to the back plate and a wire connection or two? If so, how difficult is it gonna be to make the new wire connection to the new coil?
I haven't tested it yet, but I swapped in a known to be working CDI and coil and it was still not getting spark. I have also disconnected the kill switch. I very much suspect one or all of the coils on the stator have punched their own ticket. If it turns out just one has gone bad I would like to only have to replace that single coil as it seems to be a lot cheaper to just replace the coil itself rather than replacing the entire unit.
Thanks
Mouthfulloflake
ISJWTA member #2
NW Arkansas
the specs are posted as well as the schematic so you can use an ohm meter to test for resistance thru the various coils and get a pretty good idea if they are workable or not.
Other wise, its simple remove the broke coil, and resolder a known good coil in its place.
coils of that vintage though, are well, OLD.
the varnish used to insulate the windings breaks down after so many years and heat cycles.
I think ive seen the indivdiual coils for sale from jet-world...
Yeah, I just found the specs to test each coil in another thread and I've found replacement coils for around $35 a piece. Thanks for the info.
