Premierpower
Riding dirtbikes and waterbikes
- Clermont, FL
'95' Kawa 550SX
All wiring is normally connected. Think of the relay as a line and load. Coil that goes from batttery to relay(Line) is 12.5V.Coil from battery to relay(load side) when i press starter button is only giving me 50% 5-6V. When i remove coil(wire) from relay to starter and recheck voltage i read 12V. I checked resistance of wire and am reading 2-7 ohms. I tested a new coil(wire) and am reading the same resistance. I installed a copper 6awg wire and all i am getting is clicking.
HELP HELP HELP?!?!?!
When all is connected normally i get 6V on load side of Relay. When i remove the wire to starter and check voltage, i read 12V?!?!?
