The start switch on my 1995 superjet is working sporadically. I have tested continuity to the start/stop switch and it tests OK. The start switch works sometimes but other times nothing happens. I disconnected the quick connector when it wouldn't work and tried jumping the wires but nothing happened there either. I pulled apart the ebox, checked all the wires and everything looks OK. Tried starting and it worked fine for a while, but then stopped again. Starter relay seems to be OK if I jump terminals.
it acts like the lanyard isn't connected but it is. is there a way to test the kill switch? is the cdi or voltage regulator involved in starting the jetski? any suggestions on how to troubleshoot?
thanks
thanks
