Blaster spark or a reed?
I have a ski that is very rich in one cylinder but just fine in the other and its a 61x motor compression is 152 psi both cylinders and im leaning towards a bad plug wire. I have ruled out the plugs by changing them and still does the same thing. but want another opinion. I am leading towards a bad plug wire that is intermitant
well this one turned out to be the plug wire it looks like started pulling wires out and some jacka** went and didnt put the right caps on the wires. they were just a spring with a wire going tthrough the spark wire. swapped over and has started every time and idles alot better. now just to test it
Tuscaloosa, AL
It has been so long since I have fooled with Stock Electronics, but that spring sounds like the OEM setup.....
