Super Jet some epic wiring questions
It appears that I have everything wired together but I cant get the motor to turn over. Plugs are out, know good battery with a full charge, new jss battery cables.
My question is in the instructions there is a black wire that connects to the ground post with a second wire with a male bullet connector that connects to the black wire of the oem harness. Where does the black wire on the coil plug in?
Should plug into a black wire on the CDI (EPIC).
That has nothing to do with your ski not turning over, though.
Make sure:
  • The black wire from the stator is connected to a grounding post in the ebox.
  • The small black wire coming off the starter relay is grounded.
  • Your fuse is good
Now take the small red wire (maybe brown) coming from the starter relay and touch it to the big relay post that has the battery cable connected to it.
It should turn over.
If it doesn't, you either have a ground/power wiring problem or your relay doesn't work.
steve-uk
Manners cost nothing
Barrie - ontario
this should help
attachment.php
Thanks Matt and Steve. I jumped the brown wire and it turned over. I think my red wire isn't hooked up right.
I connected the red wire out of the cdi to the regulator using the red jumper wire. On the other end I connected the fuse end to the red wire on the start stop switch and hooked another jumper wire to my positive battery cable side on my solenoid.
