SOLD
I am looking to get into something with fixed steering, so I am selling my 2015 Air Blair Dart.
Lots of work went into this hull over the last two years:
  • Cut the tray open and de-foamed it
  • Replaced the water lines and trim cable tube with brand new ½” stainless steel tubing
  • Removed the fixed rear foot holds and widened the tray
  • Packed the tray with pink foam
  • Rebuilt the gunwales and tray to accept Rickter Ninja style brackets and foot holds, tray and side walls are very heavily reinforced!
  • All new turf with ¾” padding
  • Added Versiplug tray drains (with the Versiplug threaded mounting plates that accept the Yamaha drain plugs)
See the pics, the tray is huge! Still has front Air Blair foot holds as well. I never got around to buying the Ninja foot holds since I primarily ride surf, but they can be added at any time.
The hull is titled and registered in the state of Michigan, in my name.
The prop, pole, steering components, bar, grips, and cables all have been in the water about a half dozen times, everything is still like new.
$5200 for everything listed below:
  • Glass Dart hull and ride plate
  • Matching, custom aluminum fuel tank
  • Battery box
  • KP handle pole
  • KP chin pad
  • KP steering OVP (sealed bearings)
  • Rickter pole bracket
  • Rickter breather tubes
  • Blowsion riser bar
  • Thrust finger throttle
  • ODI grips
  • Steering cable
  • Throttle cable
  • Rule bilge pump and wiring
  • Bilge pump switch
  • Thrust low profile bilge fitting
  • Thrust low profile pisser fitting
  • OEM 155mm pump (tapped for dual cooling), drive shaft, and nozzle
  • Skat 6/12 big hub prop with 5mm cutback
  • Spare Blaster 2 length drive shaft
$3300 if someone just wanted the bare hull and matching fuel tank.
Hull is located on the west side of Michigan, about an hour south of Wave Rave.
  • Battery box
  • KP handle pole
  • KP chin pad
  • ODI grips
  • Steering cable
  • Throttle cable
  • Bilge pump switch
Burrman can you please pm me
