DylanS
Gorilla Smasher
- Lebanon Pa
I have two Square nose hulls I no longer have the room for and need to get rid of.
The black one has fresh paint, but the quality of the top deck paint is not the best, seems like it wasn’t prepped right.
Bottom deck was rolled on gel coat.
I was intending on wrapping this ski which I would advise.
Black hull has tray cracks from where the painter filled my pump threads with gel coat and ran the tap too deep.
It had a side exit exhaust, which I will include the exit for, that either needs patched or a dual exit water box to use. Ski has oem box and exhaust tube in now.
There is gel coat in the ride plate threads.
I will include pics of any other paint blems etc.
there is what seems to be inwards warp on the left tray side of the ski.
The white hull was a parts hull. I don’t believe it has any cracking, she’s just ugly.
The pole has a chip and the threads for the steering pad are busted on one side.
Black hull will include everything w/billet cap except side plastic bumpers unless I find them.
White hull will include what’s pictured and a hideous blue hood minus finger throttle.
Ski will need midshaft, pump, rideplate, tank, waterbox, long block, mounts, lines, throttle lever , both cables, and turf to run.
As of now the guy I got the ski from cannot get a title for it, so no title unless it works out before sale.
Both hulls as described im asking 325.
I can include a used xscream dual exit waterbox kit, 144 pump assembly (old school skat prop for 650 bearings feel good) with ocean pro steer nozzle , ocean pro plate, midshaft that needs rebuilt, used oem superjet mounts, oem tank, and billet fuel cap, protec intake grate for 9 total.
I can dm specific pics too.
