long beach local
long beach local
- Az
Up for sale is a nearly complete motor. RTR it has an almost new lightweight ADR crank only 2 were ever made with nylon crank webs. less than 8hrs fresh water on the crank with a ported pro-tec cylinder 85mm big bore sleeves that was welded but in perfect working condition ,cases are ported and epoxied by HPE as well as bored for larger sleeves . Carbs are 48mm Blackjacks with Rad valve reeds, Boyeson intake etc all are in excellent condition. Also included is an ATP twin spark total loss ignition. This motor makes Big power for its Size. It is jetted really close , the ignition is in time, and squish is set around .050 all that is needed is a Full Girdle ADA type head. 2500$ takes everything in the pics.
