the whole ski is plastic. The fuel door cover is some type of plastic (not sure what?) but the topdeck is metton and the bottom is SMC. When reinforcing the sides, sand ALL the white off down to the metton, which is black, and lightly transparent when you put a light behind it. The SMC is ready for glass with just a little sanding. Sand all areas with 40 or so grit for good adhesion, make sure you get to the metton!
Fiberglass is more then flexible enough to handle the flexing plastic body.
If you wanna reinforce for the surf, do the sides with 17 oz matback, one layer should be fine, go from the lip all the way to the bottom. Most people grind the ribs off, however I just did a repair and instead of removing that strength adding piece, I filleted them and glassed right on top of em.
Handle pole area, just layer that up, same glass (17 oz matback). Some people put a layer on the bottom as well, I did to be safe. Also the back area in the tray, its hard to do through the foothold holes, but an added security. Thats it, except for the hood, but thats been covered many times over. Nose can be reinforced, mike serlin style, filled it with foam and glass on top. I've also heard to wet out carbon, and roll it hotdog style, and stick that in the lip, and put carbon on top of that, so it doesnt crush if you hit the bottom.
A layer of 17 oz matback on the sides and bottom etc. should be good enough for the surf, am I right? (second opinions)
