sn mid shaft?
tbaer
USMC
BEAUFORT SC
I have a mid shaft and bearing for a sn. Should the shaft pull right out of the bearing/housing? Also can the bearings be replaced and where would i get the bearings?
tor*p*do
Squarenose FTW
NW NC
it is supposed to be pressed on
if it is loose, you need to pull it apart and replace bearings and seals
