onesojourner
I use a thumb throttle.
- springfield, mo
I am still having problems with my superjet not wanting to start after I have been riding it. If I let it set for 5-30 minutes It will start up. It seems to happen almost every time the ski is shut of or I just let it idle and die. I rebuilt the carbs and the fuel pump.
UPDATE: 8/4/08
I rode around for 20-30 minutes yesterday. The ski was fine. I might have gotten a little water in there and the ski stuttered a couple times but It got over it. I took it back to shore let it sit for 1 minute and tried to start it - it didn't start I went and grabbed the tool box and popped in some new plugs and it still would not start. Also while putting the plugs in I noticed the motor seemed to be a little warmer than normal. It was not to hat to touch but it was close. I let the ski sit for 1-2 hours in the water and it still would not start. I took the ski out and put it on the trailer, still no start. While cranking it on the trailer there did seem to be a good amount of water coming out of the exhaust but I don't think that it was that unusual. I prob got a half gallon coming out just cranking it. I tried the ski again an hour after I put it on the trailer, still no start. I drove the ski home (45 minutes) and it started.
2000 sj
stock dual 38s - primer
bpipe
What I have tried so far:
Rebuilt both carbs and fuel pump
Added a primer
removed the hose from the tank vent
Last you my ski was top notch and the first few rides this year. Nothing was changed on it when this started happening. I really and getting tired of getting towed back...
UPDATE: 8/4/08
2000 sj
bpipe
Added a primer
