- Delray Beach, FL
Got no reply in superjet section. I was at the sebastian inlet this past weekend and the ski ran fine until it was time to leave. It bogged down and died, so I figured I needed to switch it to reserve. I was in the water when this happened and it took a good minute to get it running again. It would idle momentarily then die off when i blipped the throttle. I had to do this progressively and eventually it cleared up and got me to the boat ramp. When i was flushing it on the trailer, after a few minutes of running, it died. I would be able to get it to start up again but it would die again after a few seconds of idling or if I touched the throttle. I still cant get it to idle for more than a second now. I left it in the garage and now the entire garage reeks of gas although I see no visible leak. I changed the plugs and nothing helped. I have slim to no mechanical skills for diagnosing these issues, but I'm willing to try if I can be pointed in the right direction. I did just order a new fuel filter and figured it was a decent start.
Thanks
Thanks
