Super Jet sj won't start electrical prob
Ski won't turn over when I hit the start button but will if I jump the solenoid. Took the start/stop switch apart, its good. Tested and i'm getting power to the start switch as well. Battery is good. Maybe the solenoid is bad? Bad wire connection somewhere?
Check the connector from start switch just outside e box, just had to change mine.
