NVJAY775
My home away from home.
- Gardnerville, Nevada, United States
Strange issue with the new toy. (Converted from sxi to rn sj)
Rode and ran excellent. Took on a bit of water, ran rough back to shore. Thought it just watered a plug.
Pulled plugs, cranked out (no water in cylinders) put in a fresh set of plugs. It would fire every 10 cranks or so, but only one cylinder. It wouldn't run, just fire once and keep cranking.
Then the starter would spin, but not engage. Pulled the front cover to lube the starter, and noticed the flywheel bolt was a bit loose. But the flywheel was tight and didn't move. I think...
Tightened the flywheel bolt. Put the front cover back on, starter worked like a champ, but the same random single fire is still there. It has a MSD Enhancer. Thinkin it may have gone out?
I have done some searching, but am not sure. So here I am.
What are your thoughts?
Thanks in advance!
Jay
Thanks in advance!
Jay
