Orv9978
X
- New Smyrna Beach
I have a 94 superjet, last two times I went out on it after I fell a few times when I would try to crank the ski I had no spark. Yet I could unplug the black and white wires that go from the start/stop switch to the ignition box and it would crank and run just fine until I plugged it back in and then it would die. So I would bring it home and do the normal flush on the engine by unplugging the wires again. Then the next day when I got home from work it would fire right up.
So am I right by assuming the start/stop swich is somehow getting shorted out or is this some other kind of problem?
Thanks in advance for any suggestions to correct this or advice if there is something else that is going bad.....
