IceRocket1286
- Metro Detroit
I hooked up my new B pipe after a few weekends gone and my sj rips now.
However, I get about a half hour or 45 minutes into a ride and it seems to misfire, and the pisser water is REALLY hot, hotter than normal. I run single cooling. GainerA from the board came out with his SJ and his cooling is the same, he has no problem, and its not as hot as my cooling.
I have a stock 701 with a B pipe, single cooling. Cooling is routed like this : into one side of the manifold, 2 out of head to bottom of head pipe, out of head pipe to stinger, T'd off to pisser, most direct route to pisser. I plugged the extra line in my head and ran just the stock outlet to the bottom of the head pipe, and it didnt change anything. Im thinking my water is wrong.
My buddy whos been racing for 15 years has a mild SS sj, with a B pipe. His cooling goes IN from the head to the top of the head pipe. and comes OUT the bottom to the pisser. Im sure it can be run either way, depending on which part of your engine you want coooled first. Im thinking of trying it this way.
I changed plus 2 times, thinking that I fouled my plugs by ingesting water, but after riding and NOT doing any tricks or anything to suck up some water, i relaized its not the issue. If I let it sit and cool down, the ski runs fine, until it seems to get too hot. I also have no heat sensor as many people dont, so I take it easy when it acts up so I dont cook it.
My head pipe screws are top, 1 turn, bottom and middle closed
anyone?
anyone?
