After all checks and troubleshooting I thought I made a great job
because I tried to start the engine in my garage and it ran like am hitting the full throttle after that I pulled the carburetor and I cleaned it then reassembled. When I finished that I went to the shore and I placed the ski on the water and I hit the start button the ski cranked but didn’t start then I started to check the fuel lines and they were ok and I checked the plugs spark and they were acceptable after that I hit start but still not starting so I decided to remove the flame arrestors to chock the carbs by covering them by hand then the engine started for few seconds with a lot of white smoke out of the exhaust outlet which I think it happened because of oil in the bottom of the engine. Then I did the chocking again and when the engine started I hit the throttle to keep the engine running and it worked fine but with a continues clicking sound which I don’t know where it came from but when I released the throttle the engine stopped and won’t start again just cranking.
What can I do to fix this s**t
? If this is happening because of fuel lines please advise and show me a fuel line diagram for dual 38’s to match it with mine.
If this is happening because of carburetor settings then I have to tell you that my engine is 772cc with a B pipe, TDR waterbox, MSD enhancer and ignition coils and riva flame arrestors.
Please I need someone to help me and to be specific and if it needs some pic’s and videos to help, I will post anything to make it easy.
