scat track 10 x 18
Anyone know much about this size and application. I don't fully understand the numbers in relation to performance . Out board / inboard props no problem . It seems jet ski prop makers each have their own measurements. Feel free to write a dissertation on the subject if you know the physics pertaining to the subject matter.
Waternut
Customizing addict
Macon, GA
Different manufactures use different hub sizes, blade shapes, and overall length. Therefore it's hard to know what prop does what without knowing the model of it. Inboard and outboard props are easier because there is less market variance. In jetski's you have both racers and freestylers using the same engine on the same hull but want entirely different applications.
snowxr
V watch your daughters V
Waterford, MI
I spent the $$ on a set of prop pitch guages from Watcon.com. It makes it easy to compare the different props, provided you have them on hand.
