SBN46 needle valve arm
Zero Client
BeerrroooOOOT!!!
Douglasville, GA
Mikuni manual says to either make the arm flush with the carb body, or raised no more than 1mm.
So - which is right? Or is both right? This affects pop-off and flow capability.
Tuscaloosa, AL
Just what it says. Flat to no more than 1mm. It is called tuning. That is the range you can adjust it for fine tuning.
Sent from my SAMSUNG-SM-G930A using Tapatalk
