Custom/Hybrid SBN 46's on a bored and ported 701
clouse22
BDB Kustomz
Lake Orion, MI
Going to me running sbn 46's on my motor this year in a superfreak. The motor has been bored 84mm and has the cases and cylinder ported. I believe a 754cc Currently I am going to be running stock electronics, but I will be switching to total loss in the summer.
Right now, I have an ADA head with 760 domes (approx 180 compression), bpipe mod chamber, solas 144 pump with 9/15 hooker prop.
I went through the carb database and found settings from a xscream 771.
so currently the carbs are jetted
112.5 High with 5/8 turn out
117.5 Low with 1 7/8 turn out
2.3 N/S with 65 gram spring
Just wondering if this is a good starting point or not?
Thanks for the help
dfw
Thanks for the help
My wild assed guess is that your bottom screws are too rich, pilots too lean and the main/top screws way too lean. Go ride it, listen to the exhaust at 1/4 throttle for the pilots and power tune the top screws.
