Sanding the hull
dieseltwitch
Mr. Diesel
Strasburg
I'm having to sand a lot of my hull(s) (2 skis) and i'm wondering if i can use one of those little triangle sanders from home depot or should i stick to doing it by hand?
WFO Speedracer
Alabama
Heres the thing heat from power sanding releases the mold release compound that is made into the material.If you do power sand it make sure you use a good epoxy primer or primer sealer between the hull and the paint.
dieseltwitch
Mr. Diesel
Strasburg
k does it matter if its an orbital sander or a rotory sander? I've heard that you cant use those but i just thought i would ask
thanks for the heads up
