Just a quick update, after riding it and shutting it off and not starting again, I did a spark test and there is spak but will not fire. I also put some pre mix down the cylinders and it still did not fire. But after waiting an hour, it finally started again. I know a lot of you said it's the stator, but is there anything less expensive I should could try first, before replacing the stator? I also opened the electrical box and found that there was a little corrosion in there and I did put some dielectric grease on the connections, but nothing changed after I road it. Any more suggestions? Could it be a fuel problem or something with the start and start switch?
Also to be clear it runs fine when I ride it. I usually ride it for over 30 minutes and shut it off myself. It has never shut off on its own. But will not start again for over 30 minutes.
