I need to run the high volume external pump with my Mikuni 46's, I'm getting too much interference with exhaust hose in my FX-1 with DASA 850 PV motor/intake. So pulled the carb body pump off and turned them around so diaphragm is facing the cylinder.
With the stock carb body pumps I run a size 70 jet restrictor.
Should I leave it at 70 with the high volume pump or go up?
Thanks
Thanks
