Routing cooling lines - help
Peter123
C-Note
Houston, TX
Ok, you're just going to have to excuse my ignorance because I'm new to this.
I have a 94 SN 701 with a Riva manifold and pipe. A repair had to be made to the manifold, so I took out the pipe and manifold and sent them off. Before I did, I labeled the cooling lines with tape so that I'd know how to route them.
Unfortunately, while I was battlng the manifold and pipe last night putting them back in, I had accidentally peeled off three of the pieces of tape. Now I don't know if I have this thing plumbed right.
I have no clue as to if there is a "standard" cooling setup for the majority of manifolds and pipes or if each is unique.
The manifold has two fittings, one at the top and one at the bottom. The pipe has three fittings, one low up by the nose and two back toward the trey with one high and one low.
Can anybody clue me in to make sure I'm doing this right? How does the flow go?
I know that I have one line wrong for sure because I have a picture of the engine prior to pulling the pipe and manifold.
And let me just say, holy cow, what a chore putting that manifold and pipe back in was. Of course, now that I've done it once, it will be a hell of a lot easier next time, but still it was horrible. I finished up (at least until I reroute the hoses after work today) at 2:30 this morning.
gakb
gakb
Ruston, LA
Can someone post pics of their routing of cooling lines?
I have a type IV that is pissing scalding water out of the pisser and melting couplers.
The pipe came off of an 02' O nose which ran perfectly before I put it on my [ ] nose.
I know this was originally posted a long time ago, but I have the same issue. I have the exact same set up, fittings on the pipe and everything. I just put the pipe in and I don't know where to run the cooling lines. Right now my ski is set up with single cooling. Any help would be greatly appreciated.
