When somebody asks the question what pitch do I run with my set-up, typical response is x/x hooker bore you nozzle and use a stubby... I do know lighter skis are pitched differently but I've never seen the how much do you weigh question, and there is no way IMO an impeller pitch should be the same for a 200lb rider vs 100lb rider or am I wrong? If I'm right the heaver you are the less aggressive you would want to be?
Make sense or am I out to lunch
