- Charlotte NC
im purchasing a rickter fs1.....i need to know if i use an rrp pole if i need one specific for the rickter or if the rrp pole for a superjet will fit? thanks
do i need an aftermarket steering set up......the ski that the parts are coming out of is a square nose....i need all the info i can get because i am having trouble finding good info here.....lots on the fs2 but not the fs1...thanks
To me that is a big differece. Set back pump and enlarged pump tunnel is the way every hull is going now.not that much difference between the fs-1 and 2. The 2 has a set back pump and motor placement as well as enlarge pump tunnel.
yes...I have never seen any else but an RRP pole on a RickterDo i have to run an rrp pole?
. And TITAN :arms:ive seen ATP poles on alot of Rickters....
