C
CG Racing
Guest
Does anyone have the weights of a rick roy pole? Just doing some comparing
Thanks
Chuck
Thanks
Chuck
i too am thinking of switching over to the rick roy on one of my SXR's. i am now running a UMI. how does it compare? i like the look better.
zig
i'll take that UMI off you if it's shortened.:biggrin:
it is a std length, black.
i do have a sawsall, and some black duct tape.........
zig
I did not weigh mine but was told 12.5 lbs. The top cast part is the heaviest, the tube are extremely light. I went with a heavier spring from Blowsion, and it sets about midway up.
http://www.x-h2o.com/attachment.php?attachmentid=8789&d=1154990492
RRP Pole is 12.75 LBS with pad support
stock is 8.5 lbs
UMIs are 9.75 lbs
AC Rick roy =12 lbs
For a complete RRP setup you are looking at 1200 bucks
cant you convert to the x-metal....nothing comes close IMO.
Why is adjusting the pole length an issue...
I just don't see the reasoning for a adjustable pole... well, for freeriding
and the weightand price are definately high at 12.5 lbs and 900$ (estimated)
