- Windsor, Ontario
So a @BRANDO6X and I are trying to figure out if we need a fuel line restrictor (with changeable jets) in our return fuel lines or not? We are both using SBN44 carbs with the stock/oem fuel restrictor build into the return port of the carbs. We are both going to be running a/m pipes (b pipe and Nynja), high comp, overbored to 718 and 735cc, ported cases and cylinders.
What is everyone's opinion on running these a/m fuel line restrictors? Leave it as is with stock restriction or use the a/m ones and change the restriction?
