Repairs and GR mods.
Vumad
Super Hero, with a cape!
St. Pete, FL
I just got done working on my ski for the night. I got my new bilge switch from SXIpro and put it on. The old switch just hung from the bars and was broken (it broke because I zip tied it like that so it wasn't dangling, that's ok, it broke because it was rusted out anyway). I also had a broken fuel valve that was pretty much worthless. It was stuck in one position (on) so there was no reason to have it. As you can see in this picture, my efforts to free up the valve didn't work out.
Pic # 5 is Windy flying winglady. :cheer:
Vumad
St. Pete, FL
I removed my old, broken switch from where they dangeled from the bars. I removed the fuel toggle from the dash and put the switch there, and then went to home depot, got some valves and barbs and made a new fuel valve. The ski will now pull all the fuel from the reserve, with the primer hooked to the primary. I capped the primary just past the primer with a bolt that fit the line super tight. Much cheaper than a real cap.
The valve is inside the hood. I don't need a reserve. I only want to turn the fuel off when the ski is not running. I do have a connector for fuel line, so I could remove the valve and just connect the line together directly. That would essently be the same as it was before I did anything, since it was stuck to on. Now I have a valve that I can and will use.
The brass valve is slightly lighter than the stock one if anyone was wondering. It's nice because it's out of the way. If you look to the right of the valve in pic #3, you can see my nifty solution to capping the main line. Pretty bolt. I had to leave the main line so the primer had pressure to work. It wouldn't work on the same line as the fuel because it had no pressure ahead of it.
BTW, the zip ties are temp. I'll mount the valve correctly when winter hits, when I returf and add real foot holds, for now, I just ride!
Vumad
St. Pete, FL
This is the repairs from last month, shortly after I bought the ski. I purchased a new bed plate ($80! I probably sould have bought used... but the new one will last another 20 years, I shoul have bought used anyway!). The bed plate was rusted out! The bolts from the engine stuck about 3/8" past the end of the plate, and the new plate they fit super snug, that much of the plate was rusted gone. And I had a bad motor mount. I can't find the picture of the repaired motor mount. Used 4200 to repair the motor mount and it's holding strong. (Glued the top ring to the rubber of the mount)
