- Sacramento Delta
Just performed the "Quinc Primer Mod" on the FX-1 and watched the fuel be pushed out of the carb into the return line to the T where the 1/8" primer in-line is connected. Then successfully used the primer to start the ski. Will do the same mod on the Superjet as soon as I replace the check valve in it.
I have no doubt that the Quinc Primer Mod (aka the "Quinc Invert") will cure the problem I had with a new inlet vent check valve building so much good pressure in the fuel tank that it was pushing fuel up the fuel pickup (where I had it attached) past the primer plunger and into the tray. Kuddos and thanks to you Quinc!
@Quinc may I suggest that you take credit for this mod and start a thread with a photo or two?
