Refoam question
So...I am ready to refoam my Roundnose. I have a 5 cuft foam kit (3lbs density)
A question for the more experienced here: How do you go about pouring all that liquid into the ski that quickly?
I seem to remember there's about 30-60 seconds before the mixed liquid starts expanding.
The foam kit I have consists of about 3-4 gallons of liquid. Do you mix it in a bucket, and then pour it through one big hole? Or two big holes?
My concern is getting the entire thing into the cavity in time.
Any pointers?
Into the bilge.:biggrin:
Just so you know...I am planning on doing this today, at your house, with your foam - since mine's packed up.
RMBC Freeride
Vintage
Pueblo, CO
Pour in several small batches, let them expand and then cool in between each batch. Plastic beer cups for mixing/measuring each batch.
If you try to pour "all that liquid" at once...... BOOM! You're gonna have a mess!!!
you also want to do about 3 to 4 16 oz pours, instead of all at once, to avoid all the heat from the chemical reaction.
you want to do it in each side, left and right.
either cut a hole w/a 1" holesaw at the top of each gunwale then epoxy the pieces back in when youre done OR face the ski nose up and pour in the 2 factory holes in the firewall.
3lb density? is that structural foam?
also, if youre going to go the gunwale method, use some masking tape to make a "dam" so if foam does overflow, it goes into the tray only and not the side of your ski.
have acetone and a rag ready at all times!
waxhead
wannabe backflipper
gold coast
there is some good info in here
what is the std foam in a superjet
is the stuff you replace it with any lighter
or does it not make a difference
i used 4lb foam and it seems a lot more dense than the stock crap, which i *think* might even be 2lb.
heavier density = more weight but stronger and less likley to get waterlogged.
I am not too worried about the foam not being strong enough. I think 3lbs is a good compromise, especially with the heavy reinforcing I did on the back end.
About pouring in small batches....my concern was that the foam would over-expand and not be dense enough.
I will do the batches. That sounds more feasible. Sorry, no video.
But I'll post pics. In the past two days, I have installed my one-way (2 inches - HUGE!), put my footholds back in, and closed up the tray.
Phill
v Check out Little Matt_E
Kennewick, WA
Matt_E said:
with your foam.
You Bastard!!:aargh4:
I knew you would screw me out of the foam you gave me!:bs2:
Just kidding:biggrin:
Think we have enough time to do it in the kitchen?:biggrin:
It would be much warmer:arms:
T-bone
brraap....thats so 2002
stock sj comes with 2lb foam, steve recomends 4lb , i would think 3 is a good compromise.
Sorry I didn't post back sooner. I have or still am moving...not sure. :biggrin:
Anyways, we poured in small, 8-16 oz batches, 3lb foam.
The 3lb stuff was harder and more dense than stock foam, IMHO.
We stood the ski up on the nose, and used a funnel to pour foam in through 1 inch holes in the very back of the tray and the back of the gunwhales.
I used up about 2/3 or a bit more of the 5 cuft kit I had - this was for a complete refoam. But you have to consider the huge 2 inch one way valve with 2 inch pipe, that takes away some foam volume.
The bare hull, after refoam, weighed in at 120lbs. :bigeyes:
Strongly reinforced all over, though.
